Configures the maximum time between unsolicited router discovery advertisements on the VLAN.
| vlan_name | Specifies an IPv6 configured VLAN. |
| maxinterval | Specifies the maximum time between advertisements, in seconds. Range is 4 to 1800. |
600 seconds.
This command configures the maximum amount of time before an unsolicited router advertisement message is advertised over the links corresponding to the VLAN.
The following example configures the max-interval to be 300 seconds for the VLAN "top_floor":
configure vlan top_floor router-discovery max-interval 300
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
